Maps and Directions to Billing Aquadome (double circles on the map).
From the M1 Jcn 15 follow signs for Northampton on the A508, which turns into the A45 after going over a large flyover. Billing Aquadrome should be clearly signposted and the entrance is located just off the A45. Billing is about 4 miles from the M1.
From the A1 going south take the A605 from Peterborough, which turns into the A45 at Thrapston (A14 jcn), and follow the A45 for 35 miles all the way into Northampton where you follow the signposts as above.
From the A1 going North your guess is as good as mine. You could try the A421 at Tempsford going towards Bedford, and then take the A428 from Bedford right up to Billing. Its about 28 miles and goes through Bedford but is about the most direct route from the A1.
Zee. :)
Billing Aquadrome site map (Thanks Tony for getting a similar one - I think this one is clearer). :)
Layout two years ago... Not sure how close it will be this time round - but it gives you an indication... :)
Yes it is I noticed some signposts when we met up in earlier this year just of J16
The signs said use J15
Cool - Even better - no excuses for anyone getting lost or being late..... :smug: ....... isn't that right Andy...? :rolleyes:
:mad::mad::mad:
:rolleyes::lol:
Does anyone know were about we will be yet in the campsite?:?:
It will all be clarified when I get down there tomorrow morning. By the time you folks turn up, it should be sorted.......I hope.......! :yes:
OK Folks - Chances are I won't be online much now due to work, cleaning the car tonight and all the other stuff that I have to sort - So everyone enjoy the cruise down (or up) to Billing and I will see you all at some stage over the weekend.
Zee. :bounce:
