In preparation for the Scottish winter I've had the car in to a local detailer who cleaned the undercarriage and sealed with Lanoguard.
Quite impressed with how the car cleaned up for being 26 years old. Probably down to it spending most of its life in London. Hopefully it'll stay that way for many years to come.
I was recently reading an old post here that dry ice blasting was an effective cleanser of underside crud too
I’ve only ever seen it mentioned the once tho so not certain of its commonality nor effectiveness nor indeed its cost …….. nor the Post I saw it 🤔
Jonny Smith on The Late Brake Show (Youtube) swears by it. He had his imported Nissan Cedric (?) Tokyo taxi done. Not sure if it protects too though. Probably still have to use Lanoguard etc after it's done.
Great job :thumbsup: Another one saved.
You probably know but the weak spot on these is the rear arches where they meet the mud flaps. If it gets bad it just eats through into the boot. Your guys will have no doubt cleaned out the crap and sprayed in the recess but while it's clean it doesn't hurt to pop the wheel off and give it another spray with a can of Waxoyl. Lovely smell too iirc...
Yeah they've done a great job on the arches, I did notice some rust in there. Doesn't look to bad but will definitely be keeping a close eye on it. Looks like it's almost designed to hold crap like a cradle
Funilly enough, the detailer I used is in the process of investing in the kit for dry Ice blasting. Definitely something to consider next year.
When I enquired about the cost he wasn't sure but gave a ball park of around £700-1,000 which i don't see as a great expense if it keeps the car in the road for another 30 years with some new underseal
