Hi all
I’m looking for a is250c and I’m trying to find out what the audio options are.
Does the 250se L have a Mark Levinson system fitted as standard? Or was it a factory option? and is there any way of knowing whether a ML unit is fitted? More speakers etc, I can’t see any Mark Levinson logo’s on any of the pictures of cars for sale.
I’m guessing the 250se l will have the standard audio unit fitted
Any help most welcome
34 minutes ago, SussexMariner said:
Hi all
It is possible to get a Mark Levinson unit on a IS250C however theyre quite a bit rarer as you had to spec it out specifically to get it unlike pre facelift vehicles, you just have to spot the mark Levinson audio on the bottom of the radio / navigation unit to confirm it has it. The standard IS speakers are by no means bad so if you find a lovely convertible without it dont worry too much
Thank you for reply,
do you know if a Mark Levinson unit has a different speaker configuration to a standard model? Ie more speakers ? a hidden sub woofer etc? Or are they just upgraded
Slightly more speakers and different wiring loom so they’re not interchangeable Atleast not very easily as far as I know.
