IS2 Gear Assembly Grommet
Domin007
Hi all,
Has anyone replaced the gear assembly grommet, i believe mine is split so it lets more noise in from the road/tranny into the cabin...
I could get a replacement unit, but before i do that i wonderd if that grommet is a replacable part, i cant find it online anywhere as a individual part.
Thanks a lot
Not really sure why would it be split... also even if split it would have very minor impact to noise.
Also it is more like integral part of whole shifter assembly... kind of rubber base, more that a separate grommet. Basically when you take out the sifter assembly it stays attached to the bottom of assembly... seems you can only buy it with the assembly. I actually have spare shifter assembly, but again - I don't believe that noise is related to the grommet you have highlighted or how it could even get damaged.
