After four incidents of attempted or actual car theft within 100 metres, thoughts turn to security. We have LBX on order. I asked about Lexus supplied tracker as per the announcement in September but apparently that does not apply to LBX. Anyone fitted tracker, any thoughts on utility, please?
Also considering front & rear dashcams, partly for security when parked. Any thoughts on that, please?
I will be investing in disklock as basic additional security.
If you install front & rear dashcams, for security when parked, you may end up with Battery depletion issue, not only in LBX but any car, unless you install cut-off that disconnects supply from 12V Battery when voltage drops below certain level.
Tracker - if you mean GPS tracker, this is an option but the signal can be jammed (as well as GSM). I have one, and it need recharge every 2 weeks.
My dealer installed an alarm that is blocking OBD scanning, and they attached low energy Bluetooth proxi card without which you cannot start the engine, even if a thief is already inside a car after scanning your keys.
