Bootlid buggering about
Just recently my 4yr old NX300h has developed bootlid dementia.
Sometimes it'll open a couple of inches, forget what it was doing until I press the exterior button, then it carries on its merry way. On other occasions on close it will beep twice, do nothing at all, until "nudged" with either the internal close on the dash or button on the bootlid.
Any ideas what might be the issue?
Any advice would be great, even if it's what to tell the dealer, as the car is going in on a Saturday morning soon for its tracker to be fitted, so they can look into it while they have the car.
Just Hope It Works..So Many Problems with The Software..I Will Give it a BIG Miss.....!!! Try A Fine Spray on the Boot Struts With Some Lubricant But Not Too Much..!!!!
I would make sure everything is clean with no obstructions.
As said, I would try some lubricant too.
If that doesn't work hopefully Lexus will sort it. Good luck 😃
I've got some silicone lube somewhere in the garage, I'll give it a go
