Hello, good first thing, sorry for my English, since I am Spanish and I use the translator. Does this noise happen to you in the mat clip? The truth is that I step on it and it sounds like the noise of a spring mattress.
Rafael
Welcome to the forum. your English is just fine
I can't help with your query, but I'm sure someone who can will post shortly.
As it seems to be a new car, i would be taking it back to the dealer for even the smallest fault
Rafael
I took it to the dealership and they told me that they would consult with Lexus, the problem is that the car they had on display also made that noise.
3 hours ago, ColinBarber said:
Is it just the two pieces of plastic rubbing together? If so then some silicone spray might help.
The dealership should do this, I don't understand why they haven't done it. Well the only thing they did was change the mat and see that the same thing happened.
