This is the fix for those that have a rattle noise on their dashboard when driving. I found this on the main Lexus Ask-An-Owner Club website.
Quote
I had a very similar issue shortly after getting my 250UX. The chief engineer in the dealership fixed it in 15 minutes because he had experienced the same issue on some other UXs. The cover trim at the base of the windscreen, just where it meets the dash, is on with pop studs. He inserted some foam pads, and the rattle has never returned. It was a highly annoying rattle that got worse with some road surfaces.
I have a rattle coming from the rear of my car when it goes over some bumps and absolutely no-one can find what is causing it, inside or outside. Everything checks out fine. I have given up even thinking about it except briefly when I hear it again. One cause is the rock hard suspension on the ISF.
