Brand new ux300e power boot won’t close
Brand new ux300e owner. Just wondered if anything obvious I can check before going back to the dealer on Monday with it. The power boot works fine to open with all the options such as boot button, inside button and key. Will not close at all no matter what option you do. Just beeps once then nothing.
if you try the other button that I believe is the close and lock it beeps twice and even moving away quickly does nothing except make you look silly 😬
It also hasn’t been activated properly as says subscription not active and the app just errors when you try go to connected services in the app. I love technology…
Other than these little things the car is just fantastic to drive and so comfortable very happy with it. I wish it had ccs2 but I’m sure an updated model will come along with it soon enough.
Sounds like a trip back to the dealer. Things to check which you probably already have.
With the key in your pocket and no other keys in the car. Do the buttons on the inside of the boot lid work?
I think there are settings for how much to open, try setting this to max.
If it won’t close electrically, how do you close it. I don’t try to close manually as I think it will upset the motors and electronics.
I only use the app to set when to charge. The rest of the app is useless
Good luck in getting it sorted.
