Windscreen washer
Hello. Does anyone know if the LBX has a warning  on the dash, when the washer container gets very low of fluid?
Thank You
I have had the washer low alert a couple of times but it stops once the reservoir is empty - basically a warning and you then have two washes left!
My solution is to put a few ball bearings in the washer bottle, then when you can hear them rattling about you can book it in the Lexus dealer for a £25 refill of fairy liquid.   ???🤠
  • Haha 2
4 hours ago, RONNIE W HODGEKINSON said:
Never Heard Of That .......At Least On Any Car I have Owned..!!!
Both my RC and now my RX has a warning in the multi-information display when the tank is nearly empty, as did my Mercedes.
Check your handbook, from the 2020 NX handbook
I Would Of Course Insist They Put In Mild Green Supported by a Pair of Yellow Marigolds Grey.. Would'nt want to Chaff There Hands With the Ball Bearings..Heaven Forbid..!!!
