Judder through steering wheel.
vere peters
In my case, it looks to have been a failing driveshaft.  I got the same symptoms….although I got the juddering through the car itself too.  I only hope the new driveshafts - when they’ve been fitted - do indeed cure it🤔🙄
Blimey that’s an unexpected shock !
My perpetual juddering vanished all by itself after several months and I did NOTHING ……. I thought it might have simply been the very inexpensive cure of sodding stones in tyre treads just popping out and away 🤔
Sticking front caliper on my IS300 caused wheel wobble at around sixty. Freed the caliper and problem disappeared. Lift the front and see if either brake is binding.
