Is it hard to get into the 460 vs the Rx 350?
Do you mean, if you're a bit bigger or taller or a bit infirmer than normal? I am such a person who had a 460 for over 15 years.  The door opening is tall.  The wheel retracts right out of the way. The seat is comfortable, and even though there is a moon roof the headroom is fine.  When you get out, the seat is at a sensible height for raising yourself up to standing, though if you wish you can use the air suspension to raise the car a couple of inches.  You need to ensure there is enough space when you park to open the door properly.
The back is a bit rubbish though!
I've driven an RX 350.  There is plenty of room, but it's a bit of a clamber in and a slide out.  The ride of the 460 is also much better.
: o )
