Had advisory on both sides bottom suspension pins only slightly worn but don't know where they are or what they do
Help will greatly appreciated my local garage says it will cost about £650 .
Thanks John
It is an "advisory" not a "fail" Unless you have problems with the handling I would leave it and see what happens when you have your next MOT in a years time. Probably the same :advisory:
My thoughts exactly as it's only an advisory I will leave it until the next MOT .the steering is ok so no worries there
I agree. Leave it until next MOT unless you start to have issues.
Some of these MOT Advisories seem to mysteriously fix themselves like the Starship enterprise.
To be honest everything on a 2007 car is going to be slightly worn, it's a pretty meaningless statement.
Mine had the same for about 4 years until it failed. On an old car, I wouldn't bother changing anything until you have to
That'll probably be the large wishbone bushes, they look like crap from new. They've been an advisory on mine since before I got it, but the garage said there's no movement so don't worry about them.
Thanks for the replies I agree with everyone I wouldn't bother doing the repair I'll see what happens at the next MOT if I still have the car🥴
