Altezza fault code P0500
KSZ
I am having a T reg automatic Altezza and has this problem: the engine board light turns on and the ECT starts flashing. The engine loses power and it revs without pushing the acceleration pedal. The diagnostic device shows a P0500 fault code. The garage says is speed sensors and/or faulty wiring. They changed the sensors, but problem not getting away. For wiring need the wiring diagrams and I only found them in Russian language. Does anyone has them in English, or can give some advice about this problem/fault?
Thank you!
