Analogue clock
Hi all, does anyone know of a video tutorial or can tell me how to open the dash to install a replacement analogue clock in th center of the dash
Not sure. But noticed as of late, mine is not keeping the time accurately. It’s 3-15 minutes wrong (behind) depending how long it’s been since it was last driven.
Why are you looking to replace it @Ndoody?
Because it keeps dropping roughly two hours every 24 ..and I don't know how to fix, I presume it's broken. I had read the clock can be an issue
I have done this. Not to replace the clock but the ac vent as mine had broken fins. But i had to pull out the clock to fit it to the new vent. It requires you to dismantle the entire centre console. Look for videos on installing car play etc. That should help you remove the radio and ac units. Then you need to undo 4 screws on the underside of the ac vents and pull it out. But before you pull it out you need to also loosen the panel with the hood above the instrument cluster and starter button cover as the ac vent is sort of hooked on to it. Here is some more info on what i mean
https://www.clublexus.com/forums/is-3rd-gen-2014-present/753393-anyone-install-carbon-fiber-wrap-for-their-interior-6.html
