any owners in or around swansea ,would be nice to meet up
Bedroom wi dow shot plates fitted
 quicky please guys .
when I'm driving do the maps have to be on the screen all the time use my phone for sat nav
Check The Rear Trailing arm Bushes Are Not Worn Or Debonded..Seems to be a Particular Problem with a Few Of These Cars With That Plate..Other than that An Amazing Vehicle...Cheers..!!!
ok ronnie its just had a new mot last week ,if they were worn should it have been picked up
No. You can have the radio station, programme details, record playing etc shown or the Hybrid flow indicating the current power source etc.
ok ken ill have a look at changing it ,went for a good trip today drives well ,still a lot to learn
Each time I try to select ev it says unavailable. Maybe I've got to do something first.
You have to have sufficient charge in the traction Battery. One also has to be below a certain speed and throttle loading. Suggest a good read of the handbook to gain a better understanding of the requirements and limitations of the system.
Ok will do .had a quick read through
For what reason are you wanting to use the EV button?  Don’t forget the NX is a hybrid and not a full EV, therefore it is not set up for extended electric driving.
The only time I use the EV button is to take the car out of the garage to wash it without starting the ICE. the rest of the time the car decides when it need to drive on electric 🙂
just want to check its all working correctly tbh,maybe you could say why didnt you check before buying ,it came from a non lexus dealer and i dont think he knew how to use it ,i did ask ,
meeting up with a fella who used to work for lexus tomorrow ,so he will have a look at it and give me any info i need
This may help…
EV drive mode does confuse a lot of new Lexus Hybrid owners.
 What should be here guys had a look around. And there seems to be various buttons .seems odd it's open I've messaged the garage but no reply yet
I'm thinking boot release at lesst
Boot release and Auto lights. Heated steering would have been part of a pack I believe, pic taken from the internet.
hmmm garage hasnt got back to me yet, as they know the previous owner ,seems odd that whatever was there has been removed,ok its an early 18 plate so maybe didnt get all the facelifted bits ,met a fella yesterday that worked for lexus ,apple car play isnt there either,but at least he gave it a look over and showed me a few things
is there anyway i can find out the spec ,with my slk i gave my chassis number on the forum and got a complete spec list ,as everything on it was added extras all cars were slightly different.
that way at least ill know what should be there ,then look at putting it back
thanks for the info guys appreciate your experience ,update ,the garage got back to me today after speaking with the previous owner but she cant shine any light on the fact the switches are not there ,so ive found the switches in a breakers ,boot release and the light ,should be here in the week .ok so the plug connection is there i can feel it ,would you go ahead and plug it in ,whats bothering me is was it removed maybe because there was a fault,so by plugging it back in may cause something ,and how does the panel come away as it needs to be fitted from the back ,dont want to break anything ,i could plug it in and see if the things work before putting it all back, but if they dont then at least the gap is filled
