Supercharged is200
Hi I have recently bought a second hand is200 supercharger kit with an Eaton M62 supercharger and it did not come with a fuel cut defender, the pulley size is 140mm and I’m wondering if I need a fuel cut defender for this level of boost or will the car run fine and not cut fuel under boost.
Also if you do have to do something about the fuel cut, is it possible to just delete/unplug the MAF sensor to not let the car know boost levels and cut fuel, or will this lead to the car running to rich or lean and damage it.
