Can anyone help with either secondhand or new replacement dashboard clocks for my 1990 7LS 400? I recently disconnected the Battery and upon reconnection the temperature and fuel gauges now don’t operate accurately. A firm called Acutronics to look into the problem and unfortunately, they cannot help, I’ll be very grateful if anyone can help me and put me in the right direction ! Also require a sump gasket for this car .
Accutronics Newcastle upon Tyne ????   Their website doesn’t indicate this is their sort of problem to solve !
…….. for  your 1997 Mk3 Ls400 …… is there a local auto-electrician to help / check this out for you maybe  ?
can your usual servicing people advise you ? They probably use one ……. and get your sump gasket ……. has it been damaged …….. they usually last just about forever if unmolested 🤔
But I did need a new sump plug at about 200k  mikes 😄
Michael hasn’t been back to even check for responses since posting his request on Tuesday ……… that’s sad 🥵
