Hello all,
My 2024 ES300h has had a small argument with a hedge. So far it's hedge 1 lexus 0
I need to replace a trim part, but have no idea what it's called to even start searching for a replacement. It's this silver trim on the front bumper, roughly 3cm wide and tapering upwards:
The damaged one is the other (driver's) side.
Had a quick search on this forum and saw https://www.toyodiy.com/ recommended. But I couldn't really made much sense of that even once I'd found the correct model type which I think is EUR SED RHD A25AFXS CVT 4D.
If anyone can give me a name or part number I'd be much obliged.
Possibly 52713-33050 or 53106-33010 depending if you just need the chrome piece or the black bit as well
https://www.amayama.com/en/genuine-catalogs/epc/lexus-europe/es300h/AXZH10R/1947/body/5201
I'd advise you double check with your dealer, or at least use your VIN to confirm the correct part as there are several options depending on grade/year.
Really helpful, many thanks Colin.
If I may clarify a real newbie point...where the catalogue says LH and RH, is that as you look at the car from the front, or as you sit in the driver's seat?
As you sit in the driver's seat looking forwards.
