I disconnected the Power Steering Module and now have P/S light.
How do I fix this issue?
Error - C1241
Initially I have to ask, why did you disconnect the Power Steering Module?
The code you have relates to the Traction Control System not the Power Steering.
Code could be triggered after disconnecting something, however if everything works correctly, then after you start engine 3 times the codes should disappear (are stored as historic). So as above it seems this is not the whole story - yes we can say just clear the codes, but before doing that it would be important to understand why you were disconnecting P/S module and what issue you were trying to solve. Also if code has not disappeared after starting car 3 times, then most like (not always), the condition that triggers the code is still there and it is not related with you disconnecting the module (again - sometimes some codes get stuck and don't clear themselves correctly, but that is rare).
So yes - please describe in more details what you were doing and why... else clear the codes and see what happens, but then you doing it at your own risk, because that would not solve the problem, most likely just hide it.
