Windows still have water after i roll them down
Go to solution Solved by Jon Dee,
Please don't duplicate posts - I've removed your other one on the same subject.
It's been a long time since I owned an IS200 but I believe they never really wiped the windows well, the glass seemed to move slightly away from the seal and you had to apply a bit of pressure on the glass as it went down to keep it pressed against the rubber (which only works on the driver's side). I may be wrong however that it is just that your rubber seals are worn or just aren't as flexible as they were when new.
  • Solution
Those wiper strips on your car are over 20 years old now. You either have to replace them with new or use something like Rain-X to get the water to slide off the glass. Most shower cleaners have a silicone ingredient to make your shower glass sparkly clean... for a few days until it washes off 🙂
Would Agree With Colin.. I Think Your Rubbers Which clean The Glass are Pretty Much Worn and Probably replacing them would solve your problem... As To Cost ..If done at the Dealership would be Pricey...You could try  E-Bay... That would be a Lot Cheaper..!!
28 minutes ago, Playinyaself said:
I have the Same problem, but on my RCF. Do someone have the Partnumber for this Window Rubbers on a RCF for the prefacelift?
Welcome Phil,
Weatherstrip Front Door Glass LH ( I assume your car is LHD)
68172-24030
