This is probably going to be a daft question, but how do you get the internal courtesy lights to come on when a door is opened. I can switch them all on manually, but have failed to get them door operated.
Thanks, but the touch sensitive lights I found, it's getting them to come on when a door is opened, and then extinguishing after a delay. As all the cars I have ever owned since the 60's have.
  • Solution
From the handbook
Thanks very much, NemesisUK.
I'm having trouble negotiating the handbook, why can't we have a proper paper one?
Download the pdf version and simply use Ctrl+f to search for a specific word/phrase
I have a proper paper hand book that came with the LBX, and I agree the online one is next to useless.
That’s all very well if the iPad had Ctrl+f 😂
It does, there is search functionality within Safari or just when viewing a downloaded PDF.
Tap the share button and you will see “find on Page” 😀
Personally I find using the PDF much easier than thumbing through the huge paper manual.
