Amp location - NX300h
38 minutes ago, Khurram said:
I am not able to find the AMP on my NX300H premium. Is it built in to the audio?
Item 1 in the follow diagram (I've moved your question to a new post as it was off-topic in the IS forum).
Thank you Colin but it’s not there. Neither in the glove compartment or under the seat. So my question remains the same, is it built into the audio?
The JBL amp on my Prius was under the passenger seat.
If you have the basic 8 speaker audio system then it is built into the headunit. If you have the 10 or 14 speaker audio system with a sub (item 11) then you have a separate amp as shown in the diagram. There is only one location it is fitted, which is shown as item 1.
I will add that it is difficult to see/get to the amp. This is the list of items you need to remove:
    1    REMOVE REAR SEAT ASSEMBLY
    2    REMOVE TONNEAU COVER ASSEMBLY
    3    REMOVE DECK BOARD ASSEMBLY
    4    REMOVE NO. 2 DECK BOARD SUB-ASSEMBLY
    5    REMOVE NO. 3 DECK BOARD SUB-ASSEMBLY
    6    REMOVE REAR DECK FLOOR BOX (w/ Spare Tire)
    7    REMOVE SPARE TIRE (w/ Spare Tire)
    8    REMOVE DECK FLOOR BOX LH
    9    REMOVE DECK FLOOR BOX RH
    10    REMOVE NO. 1 TOOL BOX SUB-ASSEMBLY
    11    REMOVE NO. 2 TOOL BOX SUB-ASSEMBLY
    12    REMOVE REAR FLOOR FINISH PLATE
    13    REMOVE REAR DOOR SCUFF PLATE RH
    14    REMOVE REAR DOOR OPENING TRIM WEATHERSTRIP RH
    15    REMOVE UPPER DECK TRIM SIDE BOARD RH
    16    REMOVE ROPE HOOK ASSEMBLY
    17    REMOVE LUGGAGE HOLD BELT STRIKER ASSEMBLY
    18    REMOVE NO. 1 LUGGAGE COMPARTMENT TRIM HOOK
    19    REMOVE DECK TRIM SIDE PANEL ASSEMBLY RH
