Check VSC : No Engine Light : FIXED
I had the Check VSC on my 2008 IS220d for about 6 months, it stayed on even with no engine light, i found this video which had it gone in 5 mins so thought i'd share.
VSC can come on for so many reasons, however i found if you have no engine light and the VSC is still on this is worth a shot
you will need: 1 paperclip/bit of metal or wire
This is a bit of nuclear option to use, if you have Check VSC then ideally you should read the codes and understand what they mean. The "paper clip" method is hard ECU reset and re-sync, sometimes it is is needed (for example when changing ECU), but if you have VSC light for say misfire and you just reset ECU for that, then it will comeback.
