While accessing the fuse box to try to get my washers working (see another post) I came across a fuse labelled DRL.
I don't have DRLs on my 2007 RX400H, but does the presence of a fuse indicate that the wiring is there for them?  If so I'll get some. Where are they fitted on an RX400H?
I'm not near the car right now, so I can't take a look, but would that fused DRL circuit be live when the ignition is on and off when the lights come on?  Or just on all the time the ignition is on.
Thanks in advance for any advice.
DRL fuse is the daytime running light fuse which protects the circuit when the running lights are on once you switch the ignition on.
