Delayed power
Hello. I have an RX500h. I have noticed, when putting the accelerator to the floor, either from standing, or a rolling start, it can take a second before power is applied. Anyone lese found this?
Think There is a Slight lag which is Normal...!!!
Hi Ronnie. Thanks for the reply. I find it odd. I would have though the four electric motors would kick in immediately. Also, it is at least a second, which feels like an age. It doesn't feel or seem right.
I have found this with a few "modern" cars.
I think most cars nowadays are set up for efficiency and maximum MPG (or whatever) so there is a slight delay while the system changes from max. MPG to max. power.
Sport mode if you have it, helps a bit.
Jason.. If You Think Or Get a Gut Feeling Something aint Right Have a Word with the Technicians at Your Lexus Dealership They are usually pretty Good With Advice...!!!!
Sadly no change in Sports mode.
Does the power issue happen with progressive acceleration or as you mention 'putting the accelerator to the floor'?
