Does anyone know if there is a setting to prevent this happening as they usually dip too far and make reversing harder rather than easier?
( iknow there is a camera with line guidance etc but still old school!)
Put the car into reverse (engine on etc) mirrors will auto drop. Stay in reverse and then adjust just one of them up to your desired angle (either the left or right) the  back into P or N. Leave engine on (or ready mode) When you then select Reverse again it’ll have remembered your last position..
Many thanks Pete, I will try that tomorrow
  • Solution
You should be able to adjust the angle of the mirrors when in reverse to give the desired view.  They should then return to normal view when back in D or P
Check your owner's handbook for the details
From the handbook to stop the mirrors dipping...
To disable this function, select neither “L” or “R”. using the buttons mounted in the door armrest
Thanks Nemsis UK - found the "proper" owners handbook today under DFOM in owners manuals for LBX. Shame they dont print this, despite the cost/paper involved and provide to all new owners.
