Attempting to Force Regen
Hi guys I am currently trying to get my IS200D into forced regeneration. I just got TechStream and have a P244B code of "Particulate Filter Differential Pressure Too High Bank 1".
My DPF Differential Pressure reads from 0.4 psi to 0.6 psi when idle and up to temp. At 2000 -2500rpm it reads 2-3 psi.
One of the issues is that I can't get the Exhaust Temperature to reach 500C or 600C (as I read somewhere that it needs to be that high to initiate the dpf regen). Maximum its reached it 330C and that is after 40 mins of driving!
Also I'm not sure what a normal reading of the DPF would be but from other forums of other car brands some have said a clean DPF should read at around 0.1 psi when idle (I think).
Any help would be much appreciated thank you.
