Whistle from engine area after engine stop
Are you running your aircon ? My IS300H has done this for the last 2 years after shutdown if I have been running the aircon on a long journey.  I think it's normal
Yes as always, but it started making this sound just few weeks ago.. It makes the sound even at cold engine if I stop the engine after 30 seconds.. Don't think the variable of the long journey works as hypothesis.
Can't understand from where it is generated
Apparently it's coming indeed from AC. I tried to not use the AC few minutes before arriving home and after the engine is shut down it is no more making noises anymore.
Contacted local Lexus dealership and they said it's normal, also happening for other models. It's due to the coolant fluid used in the AC system that is pushed by the compressor after the engine stop. In summer the system is more under stress compared to other seasons, that's why it appeared just recently.
  • Thanks 2
