Windscreen Washer Jet Blocked
Hi All,
My wife's 2011 CT the left side washer Jet is blocked, I tried to unblock with a pin but it's still blocked, any solutions? Other than getting a new jet and if I have to does anyone know the part number. Thanks
I would remove the faulty nozzle ( get a couple of credit cards, store cards etc, push one under each side of the nozzle then push together to release the clips. It should then pop up and out)
Remove the nozzle from the pipe ( don’t let the pipe fall inside the bonnet!) then try the washers again. If water now flows either try and unblock the nozzle or replace it.
Still no flow is usually a broken pipe or a defective non return valve.
There appears to be 3 types of nozzle, take the old one to the dealer to match it up.
