I have a UX250H 21 M/Y as a second car. I want to periodically put the 12v on a trickle charge. I just want to double check that the Battery is a normal lead acid or an AGM?  I can't see anything on the top labels that indicate AGM but just wanted to check.
Thanks.
Also, if you use a smart charger it should check the Battery type and automatically selects the correct type.  That is how mine works.
