Hi , does anyone have a wiring diagram or a colour code for the plug or pin in a 2009 SC430 please
Hi Bob
thank you , I think that is preface lift , post has only one plug with 22 pins in it , trying to find if it is canbus and if so which wires are high and low value !
Sorry i dont think that post made much sense , i will write it again !!!
the link shows a pre face lift speedo with two plugs , post face lift 2005 on has one plug , a twenty two pin plug , thats what im looking for , mainly the canbus high and low value wires , so a wiring diagram of that cluster possibly with colour codes would be helpful , im pretty sure its canbus driven but may be wrong , thank you for the reply though
I am pretty sure the SC430 does not have a canbus system as you will never see a canbus immobilizer listed for it. I believe It uses an earlier ISO system but the info on it is not easy to find.  You can sigh up for a day for a nominal fee at  Lexus-Tech.eu where it has extensive wiring diagrams for the SC and from memory R/H and L/H versions.  You can also download bits for your information,
