SC430 speedometer wiring and pin codes
glenn7120
Sorry i dont think that post made much sense , i will write it again !!!
the link shows a pre face lift speedo with two plugs , post face lift 2005 on has one plug , a twenty two pin plug , thats what im looking for , mainly the canbus high and low value wires , so a wiring diagram of that cluster possibly with colour codes would be helpful , im pretty sure its canbus driven but may be wrong , thank you for the reply though
I am pretty sure the SC430 does not have a canbus system as you will never see a canbus immobilizer listed for it. I believe It uses an earlier ISO system but the info on it is not easy to find.  You can sigh up for a day for a nominal fee at  Lexus-Tech.eu where it has extensive wiring diagrams for the SC and from memory R/H and L/H versions.  You can also download bits for your information,
