Hi, my Lexus is 250 starting to avoid play cd and dvd nov and then , it shows track nr on cd but vil not play, next day maybe itt plays cd and dvd vithout problem, i hope i can use a lens cleaner disc, but i dont know if its posible to use this in a Lexus 6 disc player, hope fore advice.
I don't see why you can't use a cleaner disc. I always had more success removing the top cover and cleaning the lens with a cotton bud with lens cleaner on it. Not sure tho' how to remove the player on the Lexus like on older cars that was easy to remove with pins...  Maybe someone else on here can help on how to remove it from the dash...
Yep, use a lens cleaner disc. The type with 4 or 5 little clumps of brushes worked for me.
How to get info unit out, LHD but just imagine you are in other seat😂
