OTA update
Go to solution Solved by Xez,
Am I the only owner (not that there are very many) to have received a letter regards an OTA update to do with hazard flashers and remote pre-conditioning. The letter says only certain cars are involved - mine doesn’t have the issue so I’m hoping every owner gets the letter whether their car is being updated.
The main reason I px’d my Range Rover was because every time they did an OTA update it caused issues and invariably overwrote the previous fix of something else. I really do not want this OTA update to overwrite the range update which is worked well, even with my car having a HUD.
Reading the letter, there is no way to decline the installation, it is installed automatically.
  • Solution
Hi, no you’re not the only one; please see the thread running below. It appears to be across all models with the new software ie UX, NX and RX in addition to RZ.
Here’s hoping it doesn’t cause any ancillary problems, from another ex RR driver 😉
Thanks for that. My fingers are crossed that we don’t end up going the way Range Rover did - that said I now have no confidence in Lexus’s IT after them screwing the cars with HUDs after fiddling with the range update.
