Hi Everyone,
Just joined the Lexus owners  club.
I have the popup hood failure on the dash
Can someone please suggest a reasonably priced OBD2 scanner that can delete the error code.
Your help will be much appreciated.
1 hour ago, Nigelrt said:
Hi Everyone,
You cant delete it with an obd2 scanner. The error pertains to a safety system and is permanently recorded in your airbag ECU. You may find people on eBay willing to reprogram/reset your airbag ecu. But you need to fix the problem first i.e replace your pop up hood struts if theyve deployed or are malfunctioning. If they've deployed you probably need a new hood as well.
The bonnet/hood has not popped, just the error message on the dash
Got it in that case maybe try carista. Seems to have worked for someone in this thread
