I walked out the door the other day and noticed the passenger side square thing you remove for towing was hanging off. I had previously used the car a few times in the day and never noticed it. It was hanging off what stopped it from coming off and losing it was it is attached to a piece of rubber. I put it back in place held in place by a couple of clips and it went back on perfectly. What struck me was to get it off you would have had to use a flat head screwdriver. What went through my mind was has someone attempted a theft of some description. Any thoughts anyone.
This also happened recently with my RC.  There was no damage whatsoever, and I could find no explanation other than to suspect, because the car was one of a row parked parallel to the pavement, a direct and fortunately very slight bump from another parking vehicle or perhaps a pram or bike squeezing through.
You’re quite right that it would not have popped open on its own!
Can you see any faint marks or scratches around the edge of the opening where it would have been prised off?  It’s unlikely a thief would have bothered with the Lexus advice to wrap a rag around a screwdriver blade!
So it may well be that a prospective car thief was looking to tow it away, especially if they thought they had to tackle any visible - or invisible - security devices.
Was it parked where such an attempt might have been possible?
Alternatively, maybe someone was looking to replace a Lexus towing point cover which had been removed by someone looking to tow away a Lexus.  Or maybe building their own RC300 piece by piece?  🤔
Evening Len yes i thoroughly looked and there was no sign of any scratches whatsoever. It is parked right out side my front door in our car park. What i do know is this would not come off on its own.
I’d certainly agree with that, Brent.
Of course although you only noticed it when parked outside your house, it could have been prised off elsewhere.  But that’s obviously more difficult to control.
If you think your car is likely to be a target, do you have - or would you consider - installing security cameras to cover your home parking area?  I have a very effective eufy system that ensures it’s impossible for anyone to even approach our cars without activating camera, lights and warnings!
I have a doorbell but the activation camera is slow. Len i have the Blink system on my radar thinking of purchasing that system.
I can’t help you with Blink, Brent.
I only have experience of Eufy.
I’ve got Blink - it’s quite good.  Remember to buy a 16 or 32Gb memstick because after 30 days your free subscription will run out.  At that stage, you set it to store to a memstick if you don’t want to subscribe.
As it happens, this was one of the features that attracted me to Eufy!  The storage is subscription-free and occurs on mini SD Cards in the HomeBase and certain cameras.  So it’s expandable and totally under your own control.  I think files can also go to Cloud Storage but I don’t bother with that.
I have two excellent door bell cameras - both Battery powered but they could be hardwired; one of which has itself two cameras to record anything left on (or pinched off!) the doorstep.
Two external cameras are both solar powered - which works surprisingly well and I’ve only had to use the usb cable connection perhaps once a year - but then I do have them on a usage profile that will ensure the maximum Battery consumption.
I would also add that eufy service has been generally excellent.  They respond rapidly to queries and if you enjoy receiving a bit of fulsome gushing, you’ll not be disappointed!
Costco sells a lot of eufy systems if you’re a Member - and as I recall, that means you get the Two Year warranty as well - but check that first!
I have two excellent door bell cameras - both battery powered but they could be hardwired; one of which has itself two cameras to record anything left on (or pinched off!) the doorstep.
Two external cameras are both solar powered - which works surprisingly well and I’ve only had to use the usb cable connection perhaps once a year - but then I do have them on a usage profile that will ensure the maximum battery consumption.
Second this. Eufy are very good, been using them for over a year now, no problems what so ever. Battery lasts 3 to 4 months, takes a couple of hours to charge.
Thanks Don yes I looked and you can purchase a 4cam system that comes with a hub i think the micro usb goes into the hub thus avoiding the subscription charge. I know a couple of people on our street who have this but they pay for the subscription 80 quid for year I think. The only down side i see is the hub needs to be plugged into the mains so there is an electricity usage there wonder how much for year that will cost to run i have recently had my broadband updated to fibre and that has to be powered and I'm supposed to be trying to reduce my electricity usage. Also the cameras require batteries but i like the idea of wireless.
Daughter has the Eufy cameras and seems to like them
Aye something i spotted on the Blink they state the camera batteries will last for 2 years lithium i believe. However i reckon that will be determined by the sensitivity that has been set.
That’s true but I’ve upped the times and sensitivity on mine and they’ve done over 2 years, possibly over 3.  I had one fail because water got in it so I made a little shelter for its replacement.  I think there are prime deals next week.
I Would Then Assume Someone.s Been Meddling with it Forewarned I Would say.. Over to you..!!
Evening Don yes i purchased on prime i wont be installing for a bit though i have a bit of work going on at the house.
You and me both.  We’re decorating all upstairs bedrooms 🙄
Ive had landscaper in new double step instead of one at the front door. Relaid new patio and paths with indian slab. Levelled and reseeded back lawn. Painted front of house. Just to name a few.
