Turning alarm off?
I'm taking the ES on a car ferry shortly and apparently l have to turn the vehicle alarm system off for the passage. I've had a quick look through the manual but can't see any mention of how to do this. Has anyone any ideas how to go about this, MY22?
By memory only (often faulty!) there is a switch above your head in the panel by the rear view mirror. As to whether things vary in different model ideas well I've no idea!
I never bothered with doing it on mine for the ferry, like you I didn't know how at the time but found the switch when it kept going off overnight for no apparent reason. Turned out I had a moth inside which was dormant in the day but wanting be outside at night.
My other car had that facility for if you left a pet in the car. I was assuming for the ferry they meant if there was physical swaying of the vehicle but l could be wrong.
This; plus if you have clothes on hangers (which, we often do) they tend to activate the internal sensor if there’s a bit of a swell.
