Stock iSF intake box
  • 2 months later...
  • 4 weeks later...
Possible. Most get replaced because the intake tube gets crushed by people over-tightening the clamps after changing the air filter. I've not seen any used ones for sale in this part of the world, and the last guy that was after an airbox ended up buying new from Amayama. Good luck.
You can repair the crushed pipe. Heat gun and an object round enough to reform the pipe and you're sorted. It's also oddly string too, so won't do it again unless you over tighten again.
