Had my UX for just over a month and loving it.   However I've played around with many of the settings and ended up with satellite showing on the navigation screen, which is perfect.   Now I want to get back to the main menu to look at other things like the air condition under "cars" and can't find advice in the manual.  Any ideas?
Never used that on the screen but if you don't have the sidebar with the various options or a back arrow at the top you could try voice command... "Hey Lexus, Start Over" which should take you back to the home screen. Have you only got a car manual ?, there is also a Nav manual that goes into everything a bit deeper.
OK all sorted.  As I'd paired everything to my Iphone I just needed to leave the phone indoors and then when the car started up it reverted back to normal mode and I found everything I was looking for.  Many thanks for the response.
The Lexus manual in my opinion is pretty poor. The so called index finds nothing most times, you have to wade through all the likely looking sections before you find, by chance, what you want. Even in a printed document these days, electronic searches at the publishing stage should produce a comprehensive contents section.
Bill D.
I download the PDF manual, then do a CTRL F and type in what I am looking for and this has always found me what I was looking for.
Quote
I found this the best video on how to use all the functions on your UX. It's on YouTube from the  US by Melissa O'Connell. It's indexed too, so you can navigate to the topic that you want. It's pretty comprehensive and to the point as well.
https://www.youtube.com/watch?v=2Gy_sD6Yy_4
