Right, got myself a dragy just for fun, car is on 52k miles with hayward scott exhaust that i suppect it has some leaks and custom intake that sucks hot air from the engine bay at the moment , still waiting for a sillicone elbow to be able to finish it properly, a little bit dissapointed with the runs , thought would get something around 4.5 , can feel the heat soak as on 3rd or 4th run as i would get something around 5.1 for the 0-100 runs
anyone else have any done any dragy runs ?
Should install the 3.7 diff next month and get lightweight wheels with decent tires and finish the intake and hopefully i would be able to get closer to 4s
if that won’t help , then deleted primary cats and a flash should definitely make a difference 😁😁😁
I'd like to get my hands on a Draggy to give mine a look. With all I've done it 'should' be quite impressive. I want to do a before and after with the carbon propshaft too!
10 hours ago, jeffrosie6 said:
What you using to time your runs?
Dragy gps box , about £150 , and just download the app which is free , quite easy to use
