Hks Hiper...
I understand that to get the best possible performance uplift with the Hiper, I must bin the cat. What are the implications of this, apart from the obvious emissions problem at test time.
Has anyone actually got their car through a test without the cat, that would be interesting.
Also, if I were to replace the cat with just a length of pipe, what happens to the lambda sensor? you can just leave it tied up somewhere surely. Does the replacement pipe have to have a stabbing for the sensor?
Any advice would be most welcome.
Thanks guys
I have removed th main cat but still have the precats. The improvement is great, only negativepoint so far : check engine light comin up when in traffic jam with hot weather due to pollution level too high.
