Bonnet supports refer
on one of my earlier Ls400s decades back, I simply used a broom stick …… it works …… only other option 20 years back was Lexus Main Dealer at silly money even in those halcyon days 😄
And in all honesty how often does one really need to open the bonnet on these cars …… top up the screen wash and annual servicing 😇
Brooms and body parts have been my bonnet struts so far as well 😄 The broom only became a slight issue when I started having an explore around the radiator to see where to place the oil cooler as I had it resting on the rad cover which is when I decided to wait for the struts before committing to trying to DIY the cooler.
My mechanic has, unfortunately, had to delay my service and inspection until the 29th so gonna give the servicing (minus the oil change and probably the spark plugs) a go myself in the mean time.
I've bought the complete service kit from Lexus Direct, just wondering if anyone has changed the rear pollen filter, I can see it listed on Lexus Direct but it isn't part of the complete service part and at £80 or so for it, I wonder if there is an aftermarket variant that might be a suitable replacement?  🤔
The part number for the rear pollen filter is 88508-30110 and it looks like Autodoc has a few aftermarket options from around £20. I don't think mine has ever been changed but still looked really clean when I inspected it. I only change the front pollen filter at service time.
Thanks Dom, really appreciate you checking that out!
Had a look at the rear filter just now and I think it has been changed at some point in the car's life. It seems to be charcoal filtered and doesn't seem to grubby but probably will be something I think about changing at a later date.
Exploring more and more of what the previous owners have done to the car is leaving me quite baffled, they have added thick foam all throughout the boot and then covered the foam in some weird curtain material but none of it has been done to a particularly good standard so it's all loose and a bit bad.
Gonna rip all of that out at some point and probably re-do it properly as it seems to have damaged the boot material sadly.
Hey Sam, happy to see the progress you are making on the car already!
On the subject of BlueMusik Bluetooth adapter - assuming no one else has answered yet! - it's probably been the best pound for pound upgrade so far on my LS430 👍 It works 100%, 99% of the time, in a sense that you might need to go to Bluetooth settings on your phone around once a week and just give it a nudge to reconnect to the in-car adapter again, but other than that, it has been flawless!
That has been bodged before now and is a right mess. You may struggle to get the strut to fit on that side, which is probably why it only has one fitted.
Personally, I think the only way you will get that to work with 2 struts would be to either replace the bonnet, or else cut that piece out and weld in a new piece of steel that can be drilled and tapped to take the screw in ball joint. The joys of budget cars.
I still like the BlueMusic module. About the only problem I have found is that my phone does not always connect to it automatically, so occasionally I have to manually connect to it.
Otherwise the functionality is excellent, the sound quality superb, and it's all out of sight apart from the charger cable I fitted.
The magic of a broomstick appeals then 🤔
The joys indeed, I plan on keeping the car as long as I can so will get round to doing everything right. Fortunately, as Malc says, it isn't the most important part so I will explore some options and assess what options I can go with in sorting the bolt hole (not sure if there is a proper name 😅) out.
Really glad to hear the BlueMusik kit is working pretty well, reconnecting with my phone every so often is hardly the biggest hassle thankfully. Looking forward to getting that installed and trying out some of my own music. Currently have just been listening to the random assortment of discs the previous owner left in the disc changer!
You might be able to use a TimeSert or similar insert once you get all that epoxy mess removed, but it depends on what metal remains.
As you say, it's not urgent and a broom handle works fine so long as you wedge it into place firmly.
  • 4 weeks later...
Just to let you know, I managed get it all sorted. Turns out the sealant they botched it with hadn't been cured, so removing the old stuff and redoing it properly allowed me to fit the struts you linked! Also, managed to get the Bluetooth installed which I am very happy with so far.
So with that all sorted, I took it to the garage. The noise from the back right is the wheel bearing, as suspected, and the coolant hoses are deteriorating so will be getting that sorted in a few weeks. However, I am having a slight issue/bit of confusion when it comes to sourcing the parts though.
From what I can tell, the part number is either 42410-50010 or 42410-50030. On the LexusPartDirect it's listed as 42410-50030 but everywhere else I am looking, it is appearing as 42410-50010 like here: https://www.ebay.co.uk/itm/355680896303 or https://www.ebay.co.uk/itm/135074839595
Does anyone know the difference between the parts (if any)?
Thanks!
On 6/7/2024 at 5:14 PM, Worfell said:
Just to let you know, I managed get it all sorted. Turns out the sealant they botched it with hadn't been cured, so removing the old stuff and redoing it properly allowed me to fit the struts you linked! Also, managed to get the bluetooth installed which I am very happy with so far.
Thanks!
Hi Sam, happy to hear about the progress you are making with the car! 👏
For the wheel bearing P/N, try this link from Amayama, I've set the search parameters for UCF30R-AETGKW, which is listed as 3UZFE cars made from 07.2003 - 08.2006 (facelift), and specified options as 6FC (6 speed Auto), RHD (Right-hand drive), and EUR (European market):
https://www.amayama.com/en/genuine-catalogs/epc/lexus-europe/ls430/UCF30R/11379/chassis/4102
It's listed under "42450A - HUB & BEARING ASSY, REAR AXLE, RH" section, and here is the diagram, it appears that the part you are looking for is 42410-50010, as that's the one specified for RH (right-hand) cars. Your other best best to verify this is to call the local Lexus dealer and ask for Parts department, they are usually very good when it comes to things like this 🙂
REAR AXLE SHAFT & HUB
LexusPartsDirect on the other hand, do not specify the generation of the car, it is instead listed as "Suitable for Lexus LS Phase 3 2000-2006" and "Lexus Genuine Part Number: 42410-50030", again, might be worth getting in touch with them to confirm 👍
The 2 parts are nearly identical.
42410-50010 is marked as "EUR, HongKong, Singapore or Taiwan spec" and 42410-50030 isn't.
Since we are in EUR (despite Brexit) I would say order either one and get it fitted.
By the way, you can access the full Parts Fiche here
https://lexus-europe.epc-data.com/ls430/ucf30r/5111/?color=8P8&trim
This is for the facelift LS430 but you can get data for others from the site.
You will need to change your paint code (mine is 8P8) on the page where it shows "Trim Code".
