Before I replaced the passenger side mirror I must have shorted something because I was trying to tuck the electric wires from the door mirror inwards.
Radio and climate control and door mirror control functions are not working. The climate control backlight is on with a solid line at the bottom. The hot air seems to coming out but can't control it from buttons nor can I see anything.
Radio and clock is off.
Replaced passenger side door mirror. The puddle light comes on as per normal when you go near the car or car is unlocked.
Tried replacing radio1 + radio2 fuse nothing. Radio 3 looked blown to me but replaced that as well still nothing.
I am not sure which fuse is for the mirror control?
Anyone have any clues?
For anyone who has this problem. I have SOLVED the issue.
Using a voltage meter I tested all the fuses.
Lots of help around the internet were indicating it could be RADIO 1 or RADIO 2 which are in the engine bay.
Others said RADIO 3 which is under the drivers side fuse panel.
It turned out to be the ACC fuse which is 7.5A under the drivers side fuse panel.
According to the documentation it was for the clock, mirror controls and other things.
Hope this helps someone.
