Rx400h front brake imbalance
Hello all. Had the car in for MOT inspection and it failed on front brakes not balanced, over 20% difference.
I changed the front calipers ,hoses and master cylinder. I took it back and it passed but there is still some imbalance, to much for my liking.
The rears are more or less identical on balance.
I used a vacuum blender with the peddle slightly pressed and removed ABS fuses as Tech stream advised.
Any ideas? Could there still be air in the system? Peddle feels firm so I think master cylinder is bled ok.
I also bled rear brakes.
Edited by CJJH
Forgot to add some info
Wow, that's a lot of work, especially the master cylinder.  You didn't mention what I would consider easy things:  pads and discs.  What are they like?
What are the caliper slide pins like: sliding freely?
Changed all pads and discs about six months ago so all new.
The caliper slide pins are fine and move freely.
I'm stumped.
I think I can access the four wheel cylinder pressures using techstream data list. Might check that out.
Before you changed the hoses, calipers and master cylinder, did you identify a problem with them? Or did you change them in the hope it would fix the imbalance?
