Part numbers and advice on supply
Good Afternoon all.
My 2002 430 SC’s renovation is almost complete and all niggles rectified thanks to members help in some cases.
The original plate pie wheels have been renovated and I am looking for just 6 of the screws/ bolts that hold the plate pie onto the wheel,a part number would be appreciated and any guidance with supply would be helpful.(coincidentally we are having plate pie for tea tonight,you can tell we are from the North!)
In addition on the driver’s side at the rear of the seat the leather panel has come loose any guidance please on the plastic holding clips again with part number and potential supply.
Thanks once again for your help.
Graham Wilkinson.
5 hours ago, Graham Wilkinson said:
Good Afternoon all.
Graham Wilkinson.
From memory the seat back clips in at the top and is screwed in underneath.
Take the seat fully forward, torch and a mirror ..screw each side.
….bit tricky to get at ☹️
once you have it off you can see if any parts are needed 👍🏻
The number for the screws is 42627-24010. I bought mine from Amayama. 10 screws for £53.30 including postage from Japan.
They are just normal set screws  M8 from memory but check size as I am not sure available almost anywhere 😉
That`s great thanks for your help.Graham.
On 4/23/2024 at 7:22 PM, Bob King said:
Get marine grade in stainless steel 👍🏻
Thanks Bob.
On 4/23/2024 at 3:05 PM, Localhero said:
https://www.accu.co.uk/metric-cap-head-screws/3887-SSCF-M8-20-A2
Try here , haven't got my sc anymore so DO CHECK size my local accessory shop has them they are nothing special you can also get cone and mushroom headed ones do a search on ebay👍
Will do many thanks,Graham.
