I want to change the front number plate plinth to a shorter one as I want to mount a short UK private number plate. The UK plinth would have excess black plastic either side which I don’t want.
There appears to be a range of number plate plinths globally and the Italian region one looks perfect for my needs.
The plinth appears to mount on 2 bolts into the grille/crash bar and some clips into the Fsport grille, so I imagine they are interchangeable.
I can’t get a UK Lexus dealer to tell me what the part is or costs as they say they need a VIN from an Italian car to search for and reduce the hundreds of options available to them.
can anyone tell me a part number or is prepared to share a VIN so I can search? It must be a FSport version as the grille design is different.
Thanks in advance.
I’ve looked on the Toyota parts database and can only see one type of numberplate mounting bracket with no specific one for Italy.
If you could provide more information regarding the Italian version I will try to find it for you.
52114BBRACKET, FRONT BUMPER EXTENSION MOUNTING52114-48460152114-48510"F-SPORT"*(F)1
Mmm,  thanks for looking, I swear I’ve seen a different part online. The Italian front plate size is 355x110mm.  Need an Italian RX 5 owner to confirm what they have.
The Italy Lexus site shows a render same as UK.  Now off to try and find a pic of an Italian RX……..
