Hey guys
Been experiencing some whirring type noise when braking from what I believe is the front brakes, Ive got some new front discs and pads ready to go but before I tackle it I thought I'd get a second opinion incase its something else that could be causing the noise.
51 minutes ago, McShmoopy said:
Hey guys
Sounds normal if you're due pads change.
While you change the discs and pads, grease up the slider pins and you'll be alright 🙂
Cheers mate, I was more used to a horrible screeching noise from the brake pad wear indicators. I’ll probably use the standard pads and discs I’ve got this time around and next time consider a big brake upgrade!
GS300 Calipers you can pick up for £150-200 for the pair. Pads / Discs are pretty much the same money as IS250 stuff. I think the only extra you'll have to buy is the dust shield if you want it. That's comes up to £18.50 each on Amayama from japan.
