Why is there no car charging ports in the Lexus 2020 NX 300 H and if there is any availability or someone that can install some in the backseat area?
Not sure what your requirements are, but a portable Battery pack / power bank could be a cheaper option than trying to get charging ports installed.
Not ideal, but might work OK.
Is there not a 12v socket in the back seat area or boot?  If so you could plug a USB adapter with a couple of outlets into one of those like the item below?
USB Adapter Plug
