I have a 2022 NX350h with the 14 inch multimedia system.
Is there a way to make Bass, treble and mid-range adjustments and to adjust level of sound from rear to front or left to right speakers.
Any advise would be much appreciated.
Don't have a 2022 NX350h but all the Lexus infotainments have had similar adjustment options, if you go to Sound or DSP type of menu you can adjust the Bass Midrange and Treble as well as changing the sound levels from the speakers as well as enable auto sound leveller (compression) as well as surround sound if you have a Mark Levinson system
Thanks for your help but the only adjustable options that I see under SOUND are:
Automatic sound leveliser (on/off)
System volume (sliding bar))
Navigation volume (sliding Bar)
Navigation during calls (on/off)
Adaptive volume control (on/off)
Driving assistance volume (sliding bar)
Surround sound (on/off)
It's not where one intuitively expects it to be and in all honesty I've only stumbled across it a couple of times! :blushing:
IIRC it's hidden under the source settings menu, perhaps.....
To alter sound settings turn your radio on. When you have the radio station displayed on screen-  On the rights side of the screen you will see 3 dots. Touch them and your sound settings appear and you can set them to suit.
hope this helps
